2016-2018 Range Rover Sport
Hey all!
Finally have some time to get my Disc Italia ceramic pads installed but had a Local shop tell me Id need to have replacement sensors as well for all my calipers.
Seems excessive ? Find a new shop?
My experience is that your sensors are still good if they haven’t been tripped. As soon as you have service brake light on dash, it’s time for a new sensor.
Hey all!
Hey all!
Thanks for the info. New sensors... just changing to clean up the brake dust.
I have not replaced my pads myself but did have new sensors for the Tech. In my other vehicles that I have changed the sensors are in the Pad , and if they had not worn you can sometimes remove and re use them. Best however is to have new sensors on hand, they are inexpensive if purchased from independant store. The heat from usage often make the sensor casings very brittle and hence they brake with little force.
I agree with Bails. I change the sensors whenever I change the pads. I would not want the sensor to trip because of heat or a malfunction.
RIP Our Friend
sensor's do not malfunction nor does heat have anything to do with operation. Wear sensors are simply a wire loop that has to be broken in order for the dash light to be illuminated
