I have an 02 p38a and it's been pretty good for quite some time. However today I ran into a new EAS fault on my drive home. Here's my set up right now.
All new Airbags all around
Rebuilt air suspension valve block
replaced heat override on compressor
Rebuilt compressor with new piston seal etc.
Replaced timer delay with regular relay to remove wake up
I know I have an old engine compartment relay and fuse panel that I've ordered to replace, largely due to the blower motor issue, but I know that's not the issue.
After getting home, I put the timer relay back in since I think it's connected to the diagnostics. When I plug into the OBD with my black box kicker, it powers up but I cannot read faults or read height sensors. YES I realize that the blackbox EAS may be faulty now but it's worked every **** time. I will look for a local shop who may have an EAS fault tool but wondering if there's other things I should look at in between.
Matthew
Matthew
