1 - 9 of 9 Posts
Hi
I have this problem for a few weeks.
And the first thine i chack is the fuel pump.
So i found that is a littel bit weak so i had it replaced.
But the problem isn't solved.
What can be the couse?
Cumshaft sensor ?
I dont have any fualt on the dash.
Hi
Cumshaft sensor ?
Check your Crankshaft Position Sensor, connections and flexplate. Also worth a look at the throttle position sensor and cable adjustment.
could be fuel mixture is off due to various issues like MAF sensor or vacuum leak so worth checking fuel trims if you have a OBDII reader.
I also had the same thing in another vehicle that was a part blocked Cat, once i removed the O2 sensor before the CAT it reved fine but was loud as hell, Still it was a quick test that proved it was an exhaust blockage
It could be a clogged catalyst. Use a vacuum guage and fan the throttle, if the vacuum drops slowly then it might well be plugged.
Classic crank sensor/ignition timing signal issue.
JACK'S GRANDAD
Last one doing that at my place, had a plugged cat.
Martin
1 - 9 of 9 Posts
