The temp gauge just get up to the last blue line. When driving sand the temp gauge get up to the first white line. (Driving Temp should be in the middle)
But after driving I can hear water boiling in the reservoir. The next day there was no water loss.
What can be the problem. The pipe from the radiator to the reservoir is working can see water get pump back into the reservoir.
Car is a 96 HSE 4.6
If there is a pressure loss at the radiator reservior cap then you might hear boiling, also if you have a weak concentration of proper coolant. The cap is cheap so if you havent changed it lately, it wont hurt.
