Super Moderator
Valve block needs rebuilding. Quickly, before you wear the compressor out.
Super Moderator
Does it just drop or does it self level to the bumpstops? When you turn the ignition off and it drops, does the valve block give a tick, tick, tick which would suggest it's self levelling?
Rear drops and if you open and close door repeatedly front drops with the tick tick you describe
2000 P38 4.6 HSE
deffo a leak then! could be a bag or line to one if you are confident it's not the valve block. A single bag wont cope with the weight on its own and gives an illusion of both loosing air when one has a leak
Super Moderator
It's self levelling so the other 3 corners will drop to match the height of the lowest corner, hence the tick, tick, tick from the valve block. It's working as it should but one rear spring has a leak. Fairy Liquid/Water mixture in a squirty bottle will show you where from.
  • Like
Reactions: OLFLA59
