Hopefully, this is an easy one... tried the search function to no avail... Randomly, my 99 P38 4.0 when coming from a complete stop, and especially off a cold start, will try and die somewhere between 800-1250rpm, anything past that and it will run/drive just fine. It will idle at 750 just fine, but when I put it in gear and hit the gas itll kind of shudder till it gets to about 1300rpm, if I let go of the gas during said time itll stumble and drop dead unless I get back on the gas and bring the tach up, and then will run as if nothing happened.... fuel delivery maybe? This is really the only issue I have with the truck... it doesnt appear to leak anything... or anything like that... no overheating... Put it up to my computer and found it had been misfiring, (previous owner ran 87 thru it for a while), an MAS error. and an unknown error that I think was p1884 or something... any help would be great, thanks!
Over due service can do this, ie the oil hasnt been changed in along time.
Faulty idle control valve.
Dirty or faulty Maf/airflow sensor.
Duff battery
Changed the oil yesterday, added some Lucas too. I cant seem to find any vacuum leaks, if that helps... Gonna try a new MAF, as that could very well be the issue.
May pay to clean contacts on your old MAF and try it again, Mafs very rarely go...
