Hello, I’m a newbie here. I just bought myself a project as it seems. It is a 2002 P38. It is running a bit rough with multiple misfires. I took it to my mechanic last week and found out cylinder 5 has no compression. The mechanic dug a little deeper, he removed the head and found that cylinder 5 is damaged. Long story short, I bought myself a car with a damaged block in one of the cylinder. So here I am this morning doing my research and trying to locate a used engine.
According to Car-Part.com--Used Auto Parts Market, there are the 3 different options for the US Market 4.6L engine (first one is WITHOUT secondary air injection, second is WITH secondary air injection, and last one is called LOW EMISSION). I understand the WITH and WITHOUT secondary air injection but I don't quite understand the LOW EMISSION engine. Can someone shade some lights on this “low emission” engine?? My vehicle is equipped with the secondary air injection, I know the one WITHOUT will not work on my vehicle but what about the “low emission”??
1995-2002 Range Rover Classic
low emission applied to 2003, 2004 discovery 2 which came with secondary air and a 4.6 engine. basically as far as I know the low emissions difference was a better performing catalytic converter.
maybe some else could concur or deny...
What difference in costs to rebuild your engine versus buying someone else's potential failure, wash rinse repeat etc.....
I’m with Johnno, you have no idea what your buying, in theory you only need a short engine. You’d be better off tophat lining your block, not cheap, but if your looking at keeping it, it’s a decision which will give you peace of mind, other option is try to find a low mileage one and do a swap, but get documentation to confirm mileage..
when you say no compression, are you talking zero or low ?
Will the Disco 2 4.6 work with earlier P38 RR ?
yes it will, you will need to transfer all the ancillaries from your p38 to the d2 motor, its a straight fit just different style p/s pump, higher amp alternator, different style cooling fan, different style engine mounts and exhaust manifolds.
but all same gaskets and function.
worse came to worse, you could take a 4.6 short block and install your cylinder heads on it. this regardless of the short block having been secondary air or not. secondary air in on the heads, not the block.
Why it’s a short block, it’s worth spending a few dollars with new rings, gaskets, seals, water pump ect, your not looking at major cash, it gives you peace of mind, plus no oil leaks..
