Hi all,I have to press the unlock button on my keyfob very hard for it to work. I've resoldered 2 connections on the board and checked all of the connections with a meter ok. The lock button works fairish and I've changed the batteries for tested good ones. Any thoughts?
My key fob is not working either, how do you check the key fob, could you send me a picture of were you put the test probes to check it. thank you
Banned
Does the LED light up when buttons are pressed? Yes, it's working and probably needs syncing, no, it isn't working check the side contact the battery holder is supposed to make contact with.
