1 - 17 of 17 Posts
Read Only
Hi , I have a p38 2001 2.5 diesel Bmw engine, I had problem with starter relay, and ECU, I changed both and it runs now but only in limp mode, won’t go above 2000 rpm, have check obvious things ( vacum pipes, no error codes ) any help appreciated
Have you had it plugged in to any diagnostics to clear any faults ?.
Put where about you are in your profile, might be someone local..
Sounds as though you have fitted an incompatible engine ECU. The replacement ECU needs to be exactly the same Bosch part number as the original one or you get checksum errors.
Also a BMW car engine ECU won't work in a p38.
They are usually very reliable. Why was there any need to change it?
Read Only
Thanks for the quick responses ... I am based in Limerick Ireland ...after changing the relay under the ECU , the Jeep wouldn’t start - I will check the revisions of the ECU, and try to get my hands on a more advanced diagnostics computer to read the codes. Cheers ..
If you've put the ECU from a manual into an auto or vice versa, it won't work - and one issue is that it won't rev properly.
I would guess there is nothing wrong with the ECU, it has just lost sync. You need the diagnostics to read the EMS code in the engine ECU and then enter it manually into the BECM.
It won't start unless the codes are the same.
Also stop calling it a Jeep.
Read Only
Discussion Starter · #7 ·
Thanks guys... the ECU that was in it was 0281001677 and the replacement one is 0281001676, not sure how to tell which is a manual or auto , but the rover is an auto. After starting and push accelerator to floor it revs to 2000rpm and after 3 secs or so it revs to 3500 rpm for a split second and back to 2000rpm and repeats this cycle. When driving it won’t go above 2000rpm
The replacement ECU you have, 0281001676, is for an earlier car and is not compatible. That is the cause of your problems.
Your original ECU with the number 0281001677 is actually the same as on my car, a 2000 MY auto diesel with EGR valve. I suspect the earlier ECU is for a pre EGR engine. EGR was introduced from 1998 onwards.
You need to get the correct ECU or refit your original.
Read Only
Discussion Starter · #9 ·
Thanks again, I will look into getting the same revision or get someone to look at the original one ( tried to refit it but no life - no engine light and won’t start - still not clear why it failed in first place)
As Dave says, your original one has probably just lost sync with the BeCM so isn't being powered up. It just needs diagnostics plugging in, the code reading from the BeCM and writing into your ECU. On a petrol a loss of sync is usually as a result of a door latch or fob failure.
Read Only
Discussion Starter · #11 ·
Hi there, I got this fixed today, a local engineer was able to use components from the old ECU and put onto the newer one. So it’s back running great again. Thanks for all the help. I Have to source or repair ABS pump now as it has a low pressure fault.
I would not waste any time on the EGR, just disconnect it, take the guts out and block the pipe with a big bearing ball. I have used an older ECU on the moe modern engine and yes it can be done. Make sure you install teh air temperature sensor :)
Hi Dave,
How do you enter EMS code into BECM, manually?
I had to open this thread to find out what "limo mode" was - my P38A never had that option. :)
"The Jeep wouldn't start"!!!! What an insult!
  • Like
Reactions: Dtoyne
Hi Kapila,
I can only really speak about Faultmate, which is the system I am using. Also it is the procedure only for the diesel. Petrol models are a bit different.
You first do a scan of the Bosch engine ECU:
284421
You will see my EMS code is 277. This is stored in the Bosch engine ECU and is fixed in the factory. It is non changeable.
284420
You then enter the same EMS Code, into the BECM, where it is called "Immobilisation Code" and save it. It is then sync'ed.
Can't remember what diagnostics you have got. Faultmate can be operated in stand alone mode but really needs conecting to a pc to use all the features.
Read Only
Discussion Starter · #16 ·
Thanks for your constructive comments ... really big of you and hilarious ... hope you feel good about them. I’m glad there were other folks on this forum who were actually willing to help.
My pleasure.
I thought the Irish had a sense of humour.
You will need to lighten up if you want to own a Range Rover!
  • Like
Reactions: marty_nz and Dtoyne
1 - 17 of 17 Posts
