Hi everyone, can someone please tell me what these wires are for in the ignition switch, the connector on my harness is a different type because I have installed a 4.0 p38 v8 engine in a defender body, as well as the steering column, so I just want to know what this clip is used for, I tried going through rave but I cant find the details on this connector, I have the on, acc, and start wires figured out, I will appreciate the help 20171210_192705.jpg
You've got the normal 4 way ignition switched stuff
Pos 0 off
Pos 1 accs
Pos 2 run
Pos 3 start
Plus a key in switch NW wire
Plus passive coil R wire
Pos 0 off
Pos 1 accs
Pos 2 run
Pos 3 start
thank you so much!
