Hi Guy's..
Im looking to remap my p38 1997 2.5 and wanted some pointers..
Obviously I need to buy a eeprom programmer (which I've been looking at buying for some time)
I need the blank chips to program
I also need the dump to program the new chip.
Can anyone point me in the right direction to get the chip & dump from?
Also, I see that there are 2 eeproms within the ECU, do both of them need to be programmed or just one?
Many thanks in advance
ASH
The 28 pin eprom chips used in the Bosch engine ECU are no longer manufactured. I think they were M28C16. It has been a while since I used them. They were single use only. You can however get other suitable used eeproms on Ebay, then erase them using a UV eraser and rewrite to them. I have used 27C256 chips but you can use 27C512 chips as well and adjust the memory address.
You will need a standard Willem eeprom programmer. Lots of free software out there. I used Willem Eprom3.
Only one chip is changed that contains the fuel maps. The other contains MAP (manifold absolute pressure) data and I think the ECU sync code.
You won't find any dumps for a p38 out there. Only maps for the BMW diesel car which won't run. There are a number of ECU variations for the p38 and the maps are not interchangeable. Yours will be for a pre EGR car.
Unless you are planning on writing your own maps it is easier to buy a chip from someone who does it for a living.
Many thanks for the help..
I dont suppose you'd be interested in doing me one would you?? :)
I would like to help Ash but my chip won't run on yours. My car has a MAF and EGR whereas your doesn't.
Here is a link to a guy in the Czech Republic who writes his own chips.
http://www.ebay.co.uk/itm/RANGE-ROVER-2-5-TDS-Power-chip-Chiptuning-/221701610084?
I bought one of his chips and it goes well. Offer him 20 GBP he will probably take it. You will need to specify the exact year and ECU code.
I have since fitted another chip to take advantage of a larger intercooler. I put them into a zif socket in the ECU to swap them over easily. If you decide to go ahead I can advise what to do, or in my case what not to do.
I have only copied the chips with an eeprom programmer, which is relatively easy. I really wanted to alter the fuel maps, particularly the boost pressure, but I could not find all the map start addresses in the coding.
Ive just offered him £20.. lets see if he bites.. thanks for your help
