Hi. seems like quite a few have brake problems with their P38. Mine are all the warning lights stay on for most of the time, the brake pressure takes a while to build up. I have changed the Accumulator ,Pump, and bled the system numerous times without any improvement . I would appreciate any advise on what else I can do or what I'm doing wrong. Thanks
How did you bleed it? Exactly as per the process in RAVE or did you pretend it's got a conventional braking system?
As per the Rave system which had no result so tried a variety of different ways, pump on,which worked fine with no visible air bubbles, pedal pressure with the same result which was no visible air bubbles but the brake pedal going to the floor!!
