We recently lost the brakes on our '98 4.6hse, well to a point, the pedal goes about half way down and needs a **** hard push to get it to actually stop. It appeared to me that the accumulator was at fault so ordered and replaced, but i seem to have lost my brake pressure pump.
I can bridge the pump relay and the pump will run continuously and re-pressurise the system but whatever controls the pump relay isnt sending the correct signals.
Heres a list of things i've done so far - in no particular order!
Checked fuses, been caught out with this many times `)
Replaced the accumulator as at the time the pump was working ok
Pressure and vacuum bled brakes (not the correct way as found on this forum)
Bridged the relay to check the pump works ok
Checked both relays for correct operation
Checked fuse box for damage or burn marks - looks kinda new
Checked continuity of wiring for relays, pump and pressure switch
Carried out a confusing ohms test on the pressure switch, not sure if its conclusive tho
I'm really stuck on this, any ideas clues pointers ramblings ...... anything at all please post up :lol:
