I cant open the bonnet, it opens a little but not enough to release the catches on each side. Any tips? cheers.
First thing to try is with 2 persons: one pulling the handle inside and one pulling up the bonnet and reaching for the central catch.
If the cable doesn't move one or both catches sufficiently, it is possible (but not easy) to reach up from underneath and open them by hand.
Filip
Yes, its difficult but possible. From memory, the latches are opposite each other. So you pull toward the car on drivers side and push away from the car on the passenger side. The passenger side was much harder to reach and you have to do it by feel.
Get someone to sit on the bonnet, and then pull the lever - this release the upward pressure on the catches and makes it more likely they'll pull back
FOUNDING MEMBER
Remove the two front fixing screws from the grill. Pull the bottom of the grill outwards, it has enough flex without breaking, just enough to get your hand up to the latch on each side to operate them. Ask me how I know this works!
1999 RR 4.0, my hood release cables broke at the interior handle end. I had to remove the black plastic grille, then work my way in from underneath, finally got it released. What a pain. Then I manufactured a new handle from heavy sheet aluminum, riveted it in place, attached cables, and now it works!
Kevin in Minneapolis.
Great idea to make one out of aluminum! I’ve had two of the snap over the years. Common item to break. Thanks for the tip!
kevin
