Hi,
I own a P38 4.6 HSE 1996, which I bought with a stuffed engine, this is all done up now, almost ready for a roadworthy test.
Last week I got my Nanocom Evolution, I connected it, started the car and had a play with it, I had only entered one unlock code, so only acces to the GEMS menu.
After I turned of the car, she won't start anymore....
No messages on the display, starter motor doesn't turn over.
When I connect the Nanocom and go to Gems / outputs, and select one of the options (MILL lamp - O2 Heated sensor - fuel pump - aircon stuff) and start it, the starter motor turns over when I turn the key, and can keep doing this till I take the key from the ignition.
I don't think I changed anything, if that's even possible.
At Blackbox Solutions the say it can't be the Nanocom because it's only a diagnostics tool, but I think it did causes the problem.
I checked all the fuses and shuffled around with the relais.
I don't have a clue what it can be..
Thanks in advance.
Thanks in advance.
