That's not the correct process kretslopp. This is:
BTW I'm reliably informed by the Ministry of Pointless Metrics that it's 250 ml between min and max
CHECK/TOP UP AUTOMATIC TRANSMISSION FLUID - up to 99MY
CAUTION: When replacing the dipstick, ensure that the handle lugs fully engage with tube.
NOTE: Check the fluid level only when the engine and gearbox are cold.
1. Ensure vehicle is level, then select ’P’ (park) and start the engine.
2. With the engine running at idle speed and both footbrake and hand brake applied, move the selector lever to position ’1’ and then back to position ’P’.
3. Still with the engine running remove dipstick, wipe using lint free cloth.
4. Reinsert the dipstick fully and withdraw again to check the level.
5. Check fluid level registers between MAX and MIN marking on dipstick. For fluid recommendations. See LUBRICANTS, FLUIDS AND CAPACITIES, Information.
