Hello!
So after fixing my suspension compressor and driving around 40-50 miles, I got a CEL on my 06 RRS 4.4 with 160k miles - the fun never ends :roll:. The car was driving fine, didn't notice any slipping in the tranny, shifts were a bit on the slower jerkier side (especially down shifting). When i hooked up my code reader to the car it said it has a p0741 code "torque converter clutch stuck off".
When I bought this RRS a few weeks ago, I asked the previous owner if the tranny fluid had been done...he didn't know. I have it on my short list of things to do - along with a new pan and gasket.
My question is - is there something more I should be doing besides changing the fluid, pan and filter?
Discussion Starter · #2 ·
from researching more, seems like it's gonna need some new solenoids in the tranny. should also note that i am hearing that rumble sound from under the car - sounds like you're running over a cattle guard. looks like some $$$ is about to be dished out on this rangie
update: took the RRS to a local LR repair shop. they noticed i was a few quarts low on transmission fluid and that it was dirty, but also recommended doing the whole metal pan upgrade, which i did along with fresh fluid. it didn't fix the CEL (expected) - but they said it should be drivable, it will rev a few hundred RPM's higher, gas mileage (ha!) will suffer. they did theorize how it could be the solenoids ($700 job) or the actual torque converter ($2100 job).
they also said that there is a chance that the CEL will just eventually go away after the fresh fluid has been cycled enough times - that would be great.
but the cattle guard sound i was hearing was unrelated, turns out the rear bumper foam beam was loose.
thankfully i passed TX emissions last week before the CEL came on.
This code, to me, is self descriptive. It appears that, when the solenoid for the TCC energizes, the ECM does not see a drop in rpm. The person telling you that the code may go away may be right. I believe that the fluid may have oxidized in the trans, causing things, like the TCC, to stick. You might try changing the trans fluid several times. Use a high detergent fluid, which will clean the system. At this point, I do not believe the solenoids are defective, as the ECM can check this situation, using voltage and ground signals. The fluid passages are being switched by the solenoids, or a solenoid fault would be displayed. At this point, it appears that the ECM is expecting changes in the engine, like a drop in rpm, and engine loading, which would be precipitated by the TCC engaging. Ray
