1 - 1 of 1 Posts
Got these codes after a heavy downpour and the truck was outside the garage at the time, totally unrelated, fan clutch EGR and EVAP errors. I replaced the fan because it was a bit loose anyway. Turned out to be a 10 amp fuse, 3rd one down on the left side just has a pic of the engine on the fuse cover, not sure what it does. After reading another post I decided to check the fuses. Thankfully I didnt take it to the stealership, hope this helps someone out
1 - 1 of 1 Posts
