2015 Range Rover L405 Supercharged & 2006-2009 Range Rover MkIII / L322
Recently I've been doing routine maintenance and replaced the fuel injectors. Now i have cel p0172 & p0175 codes. Before replacing the injectors I was getting p0420 catyaltic converter code. That code has went away with the fuel injector change. Any ideas what the problem could be?
What year and engine? We need to know the basics before we even get started.
0172 & 0175 usually mean the MAF needs to be cleaned. Actual injectors would have nothing to do with it as the ECU meters fuel flow based on sensors.
2006 range rover hse 4.4 jag engine.
Had the same issue about 3 months ago replaced the MAF and the service advisor reset the adaptations to the car had no problems since
Doctor Who do you have the same model as ours is producing those codes also with a P0128 (not coming up to temp fast enough code). I cleaned the maf but lite just came on and this time its the p1175 only so far. (lambda signal weak).
