2011 RRSC
On my 07 I have been struggling with the P0171/174 bank1/2 lean faults for almost a year now. It started out after a long highway drive which is probably unrelated. I ran some fuel injection cleaner on two consecutive tanks thinking maybe I got some bad fuel. That made no difference so I have smoke tested the intake and found only a leak at the orings on the PCV. I replaced and retested to verify that leak was resolved. However the problem persists. Long term fuel trims indicate an intake system leak. I have disconnected the egr pipe and verified no smoke past the seat when the egr is closed as well. I have verified and reflashed the pcm with the latest firmware to verify it is not a mapping issue. I will try to post screenshots here showing the data but over 2500 rpm the fuel trims are near 0%. At idle they are 14% bank1 and 12% bank2 and gradually drop as rpms increase. If I manually select gears and intentionally load the engine at low engine speeds to get the throttle plate open the trims drop to 4% or so. Looking for any further advice before I take it in as it is coming up to tab renewal which requires a DEQ test. MAF tests ok as well and swapped it with a friends lr3 and the readings stay the same. Text Font Technology Screenshot Electronic device
2006 Range Rover Supercharged L322
Interesting. Did you ever go deeper with this and figure out what was wrong? I run an UltraGauge so I get live readings and the differences between banks 1 and 2 on both long and short term trims are huge sometimes. Granted, the sampling rate is too slow though. I have the very occasional rough cold starts with misfire codes and random 0171 and 0174 codes but no evident leaks.
