My 2006 range rover sport S/C starting giving me code p0170. This code comes on about 1minute after the car starts up (first i get a pending code, then after the second cycle i get the MIL). Car seems to run fine.
This is the freeze data i got:
ABSLT TPS% ....21.9
ENG RPM ..........650
BARO RPS KPA ....101
calc load %.........37.6
MAF Flow GR/SE...8.26
MAP KPA..............46
outside temp.....71
Coolant....136
IAT F.............91
IGN Advance DE ....5.5
ST FTRM1%........ 15.6
LT FTRM1%........ 0.7
ST FTRM2%........ 12.5
LT FTRM2%........ 0.0
ST FTRM3%........-100.6
LT FTRM3%........-100.6
ST FTRM4%........-100.6
LT FTRM4%........-100.6
VEH Speed MPH...... 4
ABSLT Load % 3.0
FUEL PRESS KPAG....291
FUEL SYS 1..............closed
FUEL SYS 2..............closed
REL TPS % .............. 5.8
THROT CMD%..... ..... 11.7
ABS TPS B% ............ 56.8
ACC POS D%.................14.1
ACC POS E%............... 14.1
EVAP PURGE %.........30.1
CMD ED Ratio.......... 0.969
FUEL LEVEL %........ 13.7
VPWR V............ 14.121
ENG RUN M:S.... 2:28
ABSLT TPS% ....21.9
outside temp.....71
Coolant....136
ABSLT Load % 3.0
