2015 Range Rover L405 Supercharged & 2006-2009 Range Rover MkIII / L322
I recently changed my thermostat housing for a p0116 code. Im now receiving the same code. Is there another coolant sensor somewhere that I’m missing?
What year are you referring to? Which engine?
Please add your Rover's info to your signature as noted in the guidelines.
Issue resolved. There is a second one located on the oil filter housing. After replacing it and clearing the code it went away.
I have just got this along with the fan being on full speed all the time sounds like a space ship driving along - idle raising to 1k and temp not getting hot - are these normal symptoms of said temp sensor?
