2016 Range Rover Sport Supercharged 86K miles. (Out of Warranty) is showing the following Code: PCM-Engine Petrol V6
P0089-64 (E8) Fuel Pressure Regulator 1 Performance -Algorithm based failure-signal plausibilty failure.
What is the real cause of this code?
Is it the Fuel Pump?
OR the Low Pressure and/or High Presure sensor(s)?
Software Update?
How to update the software using GAP Diagnostic?
Discussion Starter #2
The Check Engine Light disappeared for a day and a half and returned today. I overfilled the tank and it went away. When I hit 75%, the Check Engine Light reappears.
2019-2021 Range Rover Sport
Software Update?
P0089-64Fuel Pressure Regulator 1 Performance - Signal plausibility failureNOTES:
  • Monitor description. The command signal to the fuel pump driver module is above a threshold
  • This DTC is set when the powertrain control module has detected plausibility failures.
  • Fuel system leakage from the fuel tank and lines
  • Low pressure fuel pump failure
  • Check for fuel system leakage from the fuel tank and lines both internal and external of the fuel tank
  • Using the Jaguar Land Rover approved diagnostic equipment, clear the DTCs and retest
  • Check and install a new low pressure fuel pump as required
