1 - 1 of 1 Posts
04 L322 with P0011 and P0021 Codes after Vanos and Timing chain overhaul with a twist. I bought the car with what I thought would be a fairly easy Vanos repair issue. Many, many $$ later I have the same codes. The twist is that two shops now that repair BMW and Land Rover have tried to get it timed correctly with no luck :mad:.
I have replaced both Vanos units, timing chains, guides, tensioners, cam position sensors, both Vanos solenoids, crank sensor and ECM.
It will start but has no power and poor throttle response.
My question is... is there anything else that could be throwing these code other than the mechanical timing?
Thank you, Matt
1 - 1 of 1 Posts
