Hello,
Does anyone have any experience in dismantling a rear diff on a 1997 model? I took it out and now I have it on my workbench.
I need to get the crown wheel and the pinion out of the assembly, so I can replace them both.
The pinion has two broken teeth and damaged the crown wheel.
Has anyone tried to do this on their own or is this a specialist job only?
I have a well-equiped workshop and the Range Rover Workshop Manual. In the Manual I only found how to take the rear diff out, but there is nothing on how to dissasemble the diff assembly and nothing about the torque values for re-assembly.
Is there a resource anywhere on the net or does anyone know how to do this? I did a search on these forums, but I didn't find anything relevant to my problem. I did find a topic about a front diff bearing change and the author mentioned that he had to have the whole axle washed and cleaned of debris. I suppose I will have to do that as well? Are there any recommendations on what fluids to use to rinse the axle? Any help is welcome and appreciated.
Regards,
Vito
Regards,
Vito
