'95 4.0se
Driving down highway with heat set to 72 external temp 38. Warm air coming from vents like normal. I then noticed cold air coming from heat vents. I looked at my temp gauge and it was rapidly heading towards the danger zone. I immediately began to pull over but before I could come to a stop and kill the engine, the gauge hit red and coolant steam poured from under the hood. I killed the engine and checked under hood. The top hose that connects to the radiator had popped off. I was close to a gas station so after letting truck cool down I managed to make it there without the temp gauge going back into the danger zone. After reconnecting the hose and refilling the coolant I began to drive. Almost instantly the gauge headed back toward the danger zone. I killed the engine before it crossed into the red. After sitting for just a minute or two the gauge dropped to normal so I tried driving again. Once again the temp gauge shot toward the red zone. After killing the engine the gauge would go back to normal in just a couple of minutes but would head right back to the danger zone after starting the engine. Another thing I noticed was that the heater vents would only blow cold air. No matter how high I set the heat no warm air would come out of the vents.
Could this problem be a bad thermostat? What could cause the top radiator hose to pop off? In the morning I will start by checking and topping off coolant and see if I notice anything obvious such as leaks or other hoses that may have come loose.
I am over 100 miles from home so I would appreciate any thoughts or suggestions.
