Well, it’s been a long while since I’ve been on the forum, and even longer since I have owned a Range Rover, but I just bought a 2013 RRS Supercharged. It feels good to be back!
I have one issue that I am currently stuck on:
My DSC and ABS are overactive when I take a sweeping left turn (usually on the freeway around 55-75mph). This only happens when turning left. The ABS will kick on and start pulsing the front left brake. It's very annoying and I end up turning the DSC off via the button in the center console.
Here is what I have tried so far:
1) Recalibrated the Steering Angle Sensor with Gap IID.
2) Rotated and balanced tires (they are new). Had alignment checked.
3) Replaced the Yaw Rate Sensor (Part # 0 265 005 730). Recalibrated it with Gap IID.
4) Replaced the upper Lateral Acceleration Sensor in roof (Part # RQJ100011).
5) Cleaned the dirt off the Wheel Speed Sensors at hubs. Didn't clean the electrical connector end of the sensor (worth trying?)
I tested live values with my Gap IID while sitting still in my driveway and here is what I found:
283871
Obviously Body Roll Rate shouldn't be 13,107 deg/s while sitting still. Does anyone know what feeds into this value? Is there anything else I should check?
Thank you in advance.
You seem to have covered all the obvious things - so time to assume the system is actually working as it should and indicating an issue. My limited experience has been with tire pressures - I had a slow leak and when turning right my DSC would activate.
So check tyre pressures and anything else odd with tyres and suspension.
I just checked the tire pressures - all of them are spot on.
The Body Roll Rate at 13,107 deg/s while sitting in the driveway makes me feel like the system isn't working properly.
Do a hard reset of the car's systems and see if the Body Roll Rate corrects itself.
Solved this issue:
On my rear passenger wheel, the bolt that connects the tie rod to the knuckle was loose. I had gotten an alignment done a while ago and it must not have been tightened all the way. Hope this helps in case anyone else runs into this problem.
287707
287708
