Hi
I have upgraded to a Thomas 337 compressor and would like to install an outlet for compressed air.
Looking at the diagram in Rave line 6 goes to the tank. Would this be suitable?
regards
Andrew
Yes, line 6 is the tank, a T will work, I'm toying with drilling/tapping the block for a proper fitting, but not sure if it's a good idea to actually do it.
no, the block, not tank. I don't like having a bunch of T's, so I'm thinking of putting a fitting in for my pressure gage, with 150psi, the 6mm line will be OK for fililng tires (I think...havn't done it yet) I may tap off of the tank for that.
Yeah, I also started messing with this as well. It seems the best bet for the air supply to actually be useful to fill tires and run air tools (for short bursts) would be to tap into the tank's drain plug. Maybe I'll dig into this again this weekend. :think:
