Help!
My 04' HSE has developed a symptom where only hot air will come from any vent selected.
It feels as is the heat is way higher than any hot air which I recall on the coldest days, it feels like the thermostat has completely failed
This occurs when
- selector under center dash vents set to cold
- thermostat set as low as it will go
- air conditioning engaged - or not engaged
I don't know if it is a blend motor, a control or some other gremlin - just hoping someone can help me trouble shoot
thanks
Re: Only Hot Air Coming Out (and I am not talking about Trum
Are you getting an engine overheat message at all? The ECM will shut down the AC if it detects an overheat situation. I just had this happen on my '11 SC due to a thermostat housing failure.
Best of luck!
Have you checked the AC system charge/refrigerant level? Assuming you have have fan and can hear the plenum doors open and closing, that's where I'd start troubleshooting.
