Ok, my 98 range rover has one odd noise.
When you first start it up to pull out of a parking lot for example, you place it into reverse and start to back out, I hear this metal clank? It doesn't feel like driveline, tranny, or anything, just a pretty loud clank of metal going to together or something "releasing" I put it in the drive and no other noises no nothing. Also I can put it into reverse, then drive all day long after it is started and I will not get any other noise.
It is only when you first turn it on and start going. Could this simply be the emergancy break "releasing?" Maybe it is stuck and when you first get moving, it lets go?
It must be something like considering that is the only time it does it. Let me know if anyone else has had that issue?
