1 - 10 of 10 Posts
Hi all, I am looking for a full size RR. I am wondering if these vehicles ever got the revised timing chain guides? RRS and the LR4 did in 2013.
Thank you.
Thank you.
Following for the comments.
I need some clarity on this, too. The way it read made it sound like it applied to the 2012 model year. But I have a feeling they meant for the 2013 MY when production started in 2012, as with many automakers.
I have a feeling this included precisely 0 of the L322 models.
2011 Range Rover Supercharged
Based on the vin ranges listed in the official Land Rover TSB documentation, it is clear that no L322’s received the updated timing chain tensioner a from the factory. 100% of the L322s left the production line with the old defective parts.
Here the affected VINs:
2010-2012 AA306630-CA393639.
2012 Range Rover HSE
Thank you.
Nope. The guides if I've read correctly continued to have issues well into L405 land as well. But 100% for sure the L322 never got any upgraded guides on the assembly line
Im sorry for the interruption OP. If I need to start a different thread please let me know.
I have a 4.2 SC with 120k on it... it’s a nice quiet engine. How can I tell when I should do the chain?
The earlier Jag motors seem to be pretty bulletproof - 07-09 are regarded as the most reliable of the bunch. If it's not broken, I wouldn't worry about it
From what I've been able to gather, it seems the safest bet for 5-liter engines (NA and S/C) with regards to updated timing chain components is the 2016+ model year vehicles. Anything prior to that most likely had older style tensioners/chains/guides and therefore a suspect.
I agree. My 2007 HSE is so much more reliable than I ever expected it to be. The Jag 4.4 sounds great and runs great (knock on wood). I expected so many more problems than I've had. Great years for the RR.
L322 - 2005, 2006 na, 2012 sc
Add 2006 to that list... Same motor & drivetrain.
1 - 10 of 10 Posts
