Hello i have 2007 RRS supercharged and the i start car there is no check engine light it is not working at all.
can someone help me to solve this problem. seller maybe done something that turn off check engine.
here is foot of instrument cluster, please help me to solve this problem.
285087
2010-2012 Range Rover Sport
Wow! The ultimate solution to all and any "check engine" issues - just "fix" the light :)
As was previously advised you can and should get a diagnostic tool and read the codes, at least to make sure LR is safe to drive, ultimately, you'd probably need to pull out the cluster and replace the bulb/led or may be it is just blocked with something opaque so you cant see the light...
Yeah but it isn't just like an interior bulb or something, if it is out - minor inconvenience. That check engine light is how your car communicates with you that it has issues. Not seeing that lighting up is a blessing but end price could be very very expencive.
