ok I give up...how do i replace the rear wiper blade?? Help
6505 Views 4 Replies 4 Participants Last post by  RangeRoverHSE
Ok, so I have it straight down but do I just push up or what....Rave doesn't really say. I looked everywhere for a desc...
its an 06 Range btw
Re: ok I give up...how do i replace the rear wiper blade?? Help
Yes, just try to slide it towards the spindle, the arm has a U shape at the end!
The quicker way I found was to just take off the cover over the rear windshield. Good luck! :thumb:
The easy way is to turn on the whiper and turn the car off with the whiper in the middle of the window. Easy to change then.
Hehehe... tried that too. I still had a hard time removing the wiper blade for fear of bending the wiper arm too much and scratching the cover. Removing the cover after cycling through the rear wiper movement to take it to the middle of the rear glass takes a bit more time but in the end was the more prudent approach for me in my 04 Range. It should be a snap for you to change it kneedeep :thumb:
