Via a funnel through the gearbox dipstick tube
RoverJoe said:
When you say gearbox, you mean manual transmission, right? Do you fill the auto tranny in the same way?
The method I mentioned is for an automatic gearbox pre 99
If its an auto you fill it through the dipstick pipe, make sure you check the level after going through all the gears and then back to neutral
