Yes, its rather cryptic, but the manual explains it. If you have a <2010 its 7.5K, if its a 2010 you'll have to wait a bit longer.
AFAIK, the oil is synthetic on the new 2010 5-liter petrol engines (both normally aspirated and supercharged.)Ukraine Range said:Both intervals are unbelievable given the fact it isn't synthetic.
Don't do that...Jiffy Lube will screw it up for you...at least take it to an independent LR shop or a British Car shop.CB08 said:Are you guys just using the dealership for oil changes or can I trust my neighborhood quick lube place to get an oil change?
If you still want to go to Jiffy Lube, just make sure you drive it in straight.PJPR01 said:Don't do that...Jiffy Lube will screw it up for you...at least take it to an independent LR shop or a British Car shop.CB08 said:Are you guys just using the dealership for oil changes or can I trust my neighborhood quick lube place to get an oil change?
Alternatively...it's quite an easy job for a DIY'er if you're so inclined...
umbertob said:AFAIK, the oil is synthetic on the new 2010 5-liter petrol engines (both normally aspirated and supercharged.)Ukraine Range said:Both intervals are unbelievable given the fact it isn't synthetic.
