I need to replace my oil pan due to the drain plug threads being stripped out, already had a mechanic tap it out and go up the next size but its still leaking. I was told it's a job consisting of removing the whole engine. Has anyone just replaced the oil pan from underneath?
2013-2015 Range Rover Sport
There are 2 companies that make kits for this type of repair. Calvan and Timesert. You can do it without removing the pan. I use Timesert products all the time repairing Rover blocks.
Thanks for the quick reply, when i went on a search I was being to specific and couldnt find much. I like the steel insert with locktite idea.
