why do i keep getting the message engine oil level not available? on my 2013 range rover sport autobiography.
5.0 liter supercharged engine.
After car is warm or after driving, shut off car. After 10 min push button to start but do not start car. Just get the first ingnition set. Then go into menu on rover and check display. It will show results.
Yeah this is one of those annoying things that isn't explained very well. You need to let the engine run until it gets to the full running temperature. Then you need to turn the car off and wait for around 10-15 minutes. After that time turn on the ignition but DO NOT turn on the engine (keep your foot OFF the brake) and then when you check it should be visible. If you turn on the engine you will need to wait another 10-15 minutes and possibly warm it up again.
Hope this helps!
