2013-2015 Range Rover Sport
I noticed a small oil patch on the floor this morning.
Seems to be coming from between the rear wheels. Had a quick look and it looks like there may be a nut missing ?
No lights on yet....
Any help appreciated on identification
Auto part Fuel line Suspension Automotive fuel system Suspension part
is it just a case of getting a new nut ?
Thanks in advance
· RIP Our Friend
Re: Oil leak - any help appreciated
You don't need a new plug you need to tighten the plug you have. Seems very odd that would be hanging out that far. Looks like it already has sealing compound on it. The square is a standard socket handle.
View attachment 266962 -
Thanks in advance
Might just be the photo, but it looks a bit crooked? Could it be that after the last oil change(if you have had one that is), whoever did it seized the threads while entering the plug? That could be why it is out so far?
A new plug or trying to tighten it might not help?
Just a thought...
I had a rear diff leak that had these symptoms.
