I'm sure someone will come along and tell you exactly what to use, but I believe it's a sealant in a tube, something like Hylomar :thumb:
You've got that the wrong way round Rich Gems engine uses a Silicone Sealant on a Steel Sump and the Thor engine with Alloy Sump uses a Rubberised Gasket.Rich998a said:the later model P38 uses a sealant but the earlier one uses a gasket.
I think you will find this improves things. I could never really get my GEMS pan sealed up for long. My Bosch model has never really leaked more than a drop or two if sitting in the same spot for a week. What a shocking concept, make the pan out of the same material as the block and then install a gasket :lol:Col said:I have just fitted the Alloy Thor Sump and Gasket to my Gems Engine, but haven't had chance to do many miles yet to see if it cure's the leaking sump problem.Rich998a said:the later model P38 uses a sealant but the earlier one uses a gasket.
