I'm in the middle of changing the oil on my 2003 HSE. I got the oil drained and removed the filter cap, I lifted up on the filter and top pulled right off. Now I'm staring at the paper and it won't budge. The paper is pretty brittle. Is there some type of release to get the filter out or should it just pull out. It seems stuck. let me know.
thanks,
Aaron
I always get the car up to a warm temp before I do an oil change, otherwise if it's been a while, everything seizes in place. Makes the job infinitely easier. Try to twist and pull on it, if nothing seal it back up clean as you can and run the engine until it's warm I guess.
The top broke off mine, but a pull and wiggle of the paper got it out.
Dan
