Anyone know offhand what size this o ring is? http://www.roverparts.com/Parts/ERR852G.cfm Would like to have one on hand prior to taking the adapter off. Planning to remove oil filter, loosen the newly exposed bolt, pull adapter away (hopefully w/o removing oil cooler hoses), change o-ring, and reverse.. Perhaps I could simply take the filter off and tighten the bolt but should probably replace the o ring.
Discussion Starter #2
OK, turns out it is actually the oil pressure switch that is leaking! Seems pretty straightforward, anything I should know prior to pulling it?
