So I get the oil changed on a two pronged lift, with wheels dangling, and 2 days later my '05 HSE seems "lost" in terms of the height settings :think: . RR shop says this can happen if the wheels are not supported on a lift, and the solution is for them to redo the settings and see what happens. The odd thing is the front will go up, the rear will stay down, and sometimes the fault code shows and sometimes it doesn't. It's like the wheels aren't sure where they are along the height continuem. Any of you had this problem, and if so how was it solved? I can't drive it until next week as the shop is on a short holiday schedule, and I'm concerned that with the suspension in whacky mode :shock: it may be unsafe.
