Ok so I went through the EAS sticky trying to figure out my issue...
When I park the car in high mode it stays up fine (over 2 days before I drove it again). When I'm in standard mode, however, and park the rear slowly creeps down to the bump stops while the front stays up. If the rear had leaks wouldn't it slowly creep down in high mode. Relays? These are under the rear seat if I recall?
Have you checked the bags in ALL heights for leaks? They often only leak in the mode most used. For instace mine only leaked in high way mode. I could drive all day in wading or standard mode with no issues.
Good to know. Didn't realize it could leak in certain modes.
FOUNDING MEMBER
took the words right out of my mouth (or off of my website......)
