So my current Continental Cross-Contact tires which came installed on my vehicle are starting to wear out and there is no way I'm replacing with the same thing (I've only kept them this long because I didn't want to throw out tires which weren't worn yet). Currently I have 20" rims, but I'll probably need to get smaller rims. I'm interesting in knowing which tire/rim combinations I can use which are good off road tires but which will not rub when on bump stops. Or alternatively, if there is a way to install modified bump stops which are taller than stock, so that I could still limp home (assuming there are no obstacles requiring full height which cannot be avoided) in the event of a catastrophic suspension failure (ripped bag, etc, etc) while in a remote location.
I'm looking for someone who has first hand experience and has tested this on an MKIII so I don't spend $$$ on tires and then find out they don't fit when I drop to bump stops one day (sooner or later it WILL happen).
I'd love to get a set of Cooper STT but I'm pretty certain that although they may not rub at normal/off road height, they would be problematic on bump stops, so I think modified bump stops would be necessary and I'm not sure if such a product exists.
