Just an FYI, if you are going to install the Odysset PC2150 battery, you will need to also replace the ground cable. The Odyssey battery is just a little bit taller than the stock battery. This increase in height, prevents the ground cable from reaching. I used a 2 Gauge, 12 inch, battery cable. Manufacturers product number, DEKA 04215. I purchased the battery from Amazon.com and the Battery cable from jcwhitney.com
I found the same thing on mine... I installed the DieHard Platinum PM-1 which is the same battery. Existing ground cable didn't reach because the new battery is a little taller. Great battery so far. Used my stereo for 5 hours and the voltage was still 12.58, engine fired up without hesitation.
