2005 4.4i HSE m62 engine
If I replace my cluster with a second hand one, will I loose my current odometer readings ?
Are the odometer readings stored in the cluster unit, or in the ECU ?
Any suggestions ?
They are stored in the IPC (instrument panel controller) as well as the ECU and TCU I believe. You will end up with the higher mileage, either yours or the one in the new cluster if its higher, and then the cluster will have to be coded to your truck (VIN number etc.) Don't know if you can actually recode a used IPC or not.
