FOUNDING MEMBER
Hello Ladies and Gents,
I'm getting code P1332, I clear it and I come back in a day or two. I cannot find it anywhere in this forum.
The bmw number is for a knock sensor issue. Low voltage, poor connection and something else iirc. Not sure what that means. Have you heard any pinging on acceleration. Just when we thought there just could not be another oddball issue to solve.
JACK'S GRANDAD
Here ye go:
Knock Sensor 4 Circuit (bank 2).
P1332 - Knock sensor 4 circuit fault (bank 2).: Last occurrence - minimum signal
Possible causes:
  1. Open circuit C0606/37 (B) - C0627/01 (B).
  2. Short circuit C0606/37 (B) - ground.
  3. Connectors C0606, C0627.
  4. Knock sensor.
1.Open circuit C0606/37 (B) - C0627/01 (B).
SHORT_CIRCUIT
Check resistance < 5.0 Ohms .
2.Short circuit C0606/37 (B) - ground.
OPEN_CIRCUIT
Check resistance > 1M Ohms.
3.Connectors C0606, C0627.
CONNECTOR
Check for connector not correctly latched, backed out pins, damaged pins, corroded pins
4.Knock sensor.
No detail available for this fault
FOUNDING MEMBER
I saw that on the BMW site, but I replaced all 4 sensors when I did the timing guides and chains. I don't get it, why is this code appearing now.
FOUNDING MEMBER
Thanks Jack's grandpa!!
I'll check the connectors as far as I can w/out taking the intake off! well see!!
Something to consider here, guys is why the signal did not occur. What happens when the system checks the sensor is that the setup for ping occurs. This will include no EGR, low rpm and max timing advance. The system is inducing ping to check the sensor. If the system sees ping from the sensor, it will assume that the unit works and advance the timing as programmed. If, for ANY reason, the sensor does not respond with a "ping" signal, or a weak one, it will assume a failure and set a code. This will include a lower than expected temperature, lower than expected dynamic compression, meaning cylinder filling, etc. Just a heads up guys. I have seen on multiple occasions codes like this set because the driver put premium fuel in a vehicle intended for regular. High octane fuel will not ping as readily as regular, and can set codes for poor knock sensor response. Ray
FOUNDING MEMBER
Discussion Starter · #7 ·
Ok, but I've been using premium fuel for the past 6 years, I know we'r tossing ideas around, so what you are saying might make sense! Thank you!!
