OBD Software?
5223 Views 6 Replies 6 Participants Last post by  RRToadHall
Hello all, I have the OBD to serial connector used for the free EASUnlock software, and i was thinking and trying to find a free OBD software that i could utilize my cable with to pull codes and such from my P38.
Is anyone aware of something like this?
Thanks for reading
There is an app called Torque that will connect to OBD but you won't be able to use the EASUnlock cable, it uses different pins to OBD.
Thanks for reading
why not download the software from eas unlock? it is designed to work with the cable.
I read it that he wants to be able to use the cable to read OBD codes as well as using it for EAS Unlock.
+1 on the EAS cable is only for EAS. You might have some luck with one of those WiFi or Bluetooth OBD adaptors, but they will only read limited values for Petrol engine & gearbox. Generic tools cannot do any proper adjustments, and will definitely NOT talk to the other ECUs.
the best scanner tool has available app for Android and Apple products. visit here if you want to look at a reading, you use an app in your phone.
Thanks for reading
Have you try to use another apps?? Torque pro, HobDrive, OBD Car Doctor Pro...you can find and download
Harvey, that "free" software was developed by Story Wilson and for EAS only, it only works on 32 bit windows platforms. Do yourself a favor and find a full P38 diagnostic system if you are going to keep your P38 long term.
