Just returned from a week long trip to find my car had sunk down almost to the bump stops (not sure if all the way). Is this typical for only a week of sitting? I don’t recall my LR4 sinking that dramatically when leaving for a while.
Yours probably don't level because they're parked on a level surface. Mine does not have a leak, this is just how the system operates. If it did have a leak they're not difficult to track, they're generally a hissing mess... 120ish PSI leaving the system isn't quiet unless it is intermittent which would point to a valve block fault or bellow leak that seals itself depending on current ride height.Brad, I have had a 2016, now a 2013 and 2014 Autobiography and none of them ever drop below normal height nor have they auto leveled with the ignition off. I think there is a leak and if your dealer can't diagnose a great Indy shop would be happy too. Leveling for hours would drain the battery...
