2009 sport, i get in turn the key and click... try a few times with the same result, eventually it will start no problem, Ive checked the battery all good, dont believe it is the starter? anyone got any ideas what to start looking for the problem?
Discussion Starter #2
swapped the sm relay this morning as someone had suggested but still nothing? just keep turning on and off and eventually it starts? Anyone got any ideas what it might be and where to look?
Your symptoms are consistent with a bad starter. Quickest way to tell is to test for power at the solenoid. Another way to tell is to listen for clicking when you try to crank it.
ive now swapped relays, removed battery and checked connection at inner wing, checked battery voltage both on and off load and all is ok... guess its time for a new starter motor
